Question Help - not got a clue!
dazzaladuk
I have a Panasonic TV the TX-P50G10B.
It has 3 HDMI but I cannot see a HDMI ARC.
I have this linked up to my virgin box with HDMI and have just purchased a Denon Soundbar. Got it home spent hours sorting it all out but no sound.
The TV has a Digital Audio Out and 3 HDMI but no ARC.
The option on the Denon Sound Bar is using HDMI ARC or Digital In Optical.
How can I get this to work - spent a lot of cash and feeling beaten by it.
DVD-Man
I've got the same set, it doesn't have arc the S20 a year later did though.
It has digital optical out though.
Joe Fernand
AVForums Sponsor
It makes no difference if you use Optical or ARC so not having ARC on the TV is not such a big problem and in some ways may be a more robust solution as ARC can be a bit hit or mis at times.
Which Soundbar do you have?
Joe
dazzaladuk
Hi I have the denon dht s514.
Do I still need a Hdmi ?
Would I connect it up with a cable digital audio out from tv to digital optical in ???
Joe Fernand
AVForums Sponsor
Yes HDMI from your Sources to your TV - then an Optical from the TV to the Soundbar.
Joe
dazzaladuk
What cable do I need to get for the audio out to a digital audio in ?
Tv seems to be a different connection to the new sound bar
Joe Fernand
AVForums Sponsor
The TV and Soundbar have standard Optical Output/Input sockets.
Joe
Amardeep1984
Hows your DHT-S514 coming along? Mines started hissing when switched on - hoping you might have some advice on whats causing this?
