Help Nokia 6303 keyguard code
Runna
Hey guys i bought a second hand Nokia 6303 classic it came with out a charger etc so i couldnt test it once i had charged it and tested it i have now found a key locl security code i have tried the default password but it hasnt workes is there any way some one could help me out.
my imei number is
it is apparently unlock to any network and is a uk handset,
prking
If the security code has been changed then the only solution is to send/take it to a repair centre with proof of purchase. (Some years ago it was possible to generate a master code from the IMEI, but this can no longer be done)
It would be worthwhile to ask the previous owner for the code, first of all.
