Help - no picture thru VGA converter on PWD7
Discussion in 'Plasma TVs' started by timpanks, Jun 20, 2005.
  1. timpanks
    timpanks
    Hi guys,
    I've received my PWD7 today from AV-Sales and have assembled it on its stand. For TV I'm using the Sony VTX-D800U freeview box & the JS RGB-VGA converter. I've got audio going directly from the freeview box to my amp, and am using a good quality SCART lead to the converter, and a vga-vga connecter to the PC slot on the screen.
    The problem? I've got sound but no picture, and I don't know what I'm doing wrong. I've selected PC input on the screen. It doesn't display a "No Signal" message.
    It's too late in the day to call AV-Sales, so wondering if any of you guys have any insights? Would really appreciate your assistance.
    Cheers,
  2. ikon66
    ikon66
    Mar 22, 2005
    400
    Tyne & Wear
    +8
    is the input on the panel set to vga? or can you not do that with it being a panel only?
    and can you set the freeviewbox to rgb out??
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    also make sure VGA input is set to H/V sync
  4. timpanks
    timpanks
    Sorry for being dense, but how do I do that ?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    screen on presss "PC", "Setup"
    Select:
    RGB
    Label (whatever you like)
    select "signal"
    Sync "H&V"
    Most likely FV box is not set to RGB or your scart isnt fully wired (I assume red LED on JS unit is on etc)
  6. timpanks
    timpanks
    OK. It was my Freeview box not being set to RGB. Had to plug in my old TV though to make the change.
    Powered off/on to the screen and now I got a picture.
    Thanks chaps.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Enjoy mate
  8. ikon66
    ikon66
    Mar 22, 2005
    400
    Tyne & Wear
    +8
    :smashin:
