help! newbie buying decison
Discussion in 'Projectors, Screens & Video Processors' started by philipo, Oct 20, 2004.
  1. philipo
    philipo
    Right guys,
    you all seem to really know your stuff..
    i'm interested in buying a projector for my new place..
    I'd be running sky, dvd and an xbox... no data presentationat all...
    My budget is about 750 quid..
    I work on tottenham cort rd so have been wandeing up and down having a look at whats about..
    i have narrowed it down to 2 but will def consider other options..
    My 2 options are
    sharp pg b10s or the infocus x2 both for about 700 pound
    http://www.projectorpoint.co.uk/Sharp_PG-B10S.htm
    http://www.projectorpoint.co.uk/InFocus_X2.htm
    the infocus looks like it has a better spec overall with higher lumens, massivly better contrast and longer lamp life, only thing im unsure of is the dlr vs lcd debate..
    but the sharp has a better short thrown/ scrren size going for it
    please can you give me soem advice..as i dont have a clue
    all help is appreciated
    thanks in advance
    Phil
