HELP - new to technology
Discussion in 'Blu-ray & DVD Players & Recorders' started by Tirin, Nov 9, 2004.
  1. Tirin
    Tirin
    I have just bought a Panasonic DMRE85 DVD/HDD recorder together with a new Panasonic PD40 digital television. Recording on to the harddrive from Analogue gives a fine picture. However, recording any of the digital channels gives a poor grainy image. Am I doing something wrong?
    Help would be appreciated.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    22,038
    Warwick
    +2,905
    Yes. And we need more info to know precisely what :)
    - Is your TV an IDTV or are you using a Freeview box?
    - Can you be more specific - "grainy"?
    - What are your settings in Setup/Connection?
    - Are you using decent Scart cables and are they fully RGB wired?
  3. Tirin
    Tirin
  4. Tirin
    Tirin
    It seems that when I record digital in extended mode, the picture is not very good, but best quality HDD recording seems to be ok.
    Thanks anyway
