Help! New Sony Tv With Tivo Probs!
Discussion in 'General TV Discussions Forum' started by S600BYC, Jun 16, 2004.
  1. S600BYC
    S600BYC
    Jul 1, 2003
    59
    john o'groats!
    Just connected up my sony kv-28ls60u to my tivo and nokia digital box an whenever i'm watching tivo the tv seems to keep switching itself off! Normal tv is ok. Anybody got any ideas what to try next?
  2. boksbox
    boksbox
    Dec 1, 2003
    673
    28
    Chelmsford
    +93
    Best ring Tivo support, there are cases where the Teletext stream interferes with some TVs in which case you'll need a speacial firmware download that Tivo can do which turns the teletext stream off. If this is the solution it's a one way fix you can't revert to the previous firmware you'll not be able to
    record teletext.
  3. S600BYC
    S600BYC
    Jul 1, 2003
    59
    john o'groats!
    Thanks phoned them and they'll sort it out in the next 24 hours, cheers.
