help :( new jvc 32d40 geometery
Discussion in 'TVs' started by cypher007, Jan 14, 2005.
  1. cypher007
    cypher007
    Jan 2, 2005
    415
    19
    +11
    is there a service menu to setup the geometery cause ive got convergence probs and at the top of the screen the picture bends at either end inwards slightly.
  2. cypher007
    cypher007
    Jan 2, 2005
    415
    19
    +11
    jl have said they will send someone out to have a look, and if its adjustable adjust it. my question is this, if i get another set is it lickely to be better or worse, could i have a friday special? ill post some picks for you to look at in a mo.
  3. L00py^
    L00py^
    Sep 23, 2004
    129
    I would recommend getting the engineer to try and sort out the geometery and convergence problems first, then swap if you still not happy. As you could end up with a worst set 2nd time around.
  4. cypher007
    cypher007
    Jan 2, 2005
    415
    19
    +11
    this was taken and scaled down from a 3m/pixel shot from my pany 3ccd camcorder. the tv is running 1080i from the component inputs connected to my xcard, which is outputting 1080i from a pal dvd test card. unfortunately the test card is not a 16:9, otherwise the convergence would probably look even worse towards the outer edge. you can also see the slight trumpeting the picture does towards the right side of the screen, and the pin-cusion probs. please do not veiw the actual quality as this will be degraded in transfer to the cameras ccd.
  5. cypher007
    cypher007
    Jan 2, 2005
    415
    19
    +11
    bad or really bad?
