Help! New house-weird rf wall socket-rubbish freeview pic?
Discussion in 'Freeview & YouView' started by whitespaces, Aug 4, 2013.
  1. whitespaces
    whitespaces
    Jan 11, 2009
    3
    Hi, I've just moved into a new house and I'm trying to get freeview (or hd better) working.
    There is a socket on wall with 2 x rf female sockets with white plastic bits around (isolated?). I plug standard rf male into left one and freeview finds loads of channels but really bad pic on all but bbc channels. I plug into right one and get nothing.
    As the wall socket is female I have to plug other end of wire into a male to male adaptor before into tv.
    Am I doing something wrong? Is this plug meant for sky-as why would there be 2 sockets? Or is my roof arial faulty?
    Many thanks see pics for info.
  2. winston2010
    winston2010
    Jun 28, 2010
    1,900
    London
    +191
    Or is my roof arial faulty? It's aerial.
    However I suggest the right hand socket is for FM radio which would explain why it doesn't work. Is there actually an aerial connected. With a new house the feed may just go to the loft for you to supply your own aerial.
    You'd also be better posting this in the Freeview section.
  3. whitespaces
    whitespaces
    Jan 11, 2009
    3
    Yes there's an aerial connected-the house is new to me but not new.
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    If this is for Freeview, why is this post in the Satellites sub-section ?
  5. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    It's not.
  6. iaint
    iaint
    Jul 4, 2011
    640
    28
    +89
    Hi.
    Is there a masthead amp that's no longer being powered? Trace the cable as best you can; looking for something connected to the cable, likely near the aerial.
    It's not meant for sky; would expect f-connectors (screw type) if so.
    You can get m-m aerial leads from asda/b&q for about a quid. That would be something to try; cheap flyleads can be quite easy to break...
    Regards, Iain.
