Help - new CDR/CDRW/DVD writer
Discussion in 'Desktop & Laptop Computers Forum' started by phil_evans, Mar 2, 2003.
  1. phil_evans
    phil_evans
    May 24, 2002
    186
    16
    Singapore
    I've got a new Samsung SM-348B combo drive under Windows XP SP1 and installed the Easy CD Creator Basic s/w that is bundled with it. I've also downloaded the latest Samsung firmware (T505) and Roxio s/w update.
    I've now tried 4 different types of CD-R (Sony, Imation, Maxell and unbranded) at write-speeds of between 8x and 32x and every one comes out a dud. Sometimes I get a disk that has a readable TOC but never one that is 100% readable.
    Can anyone help me diagnose this problem further - its getting kind of expensive (7 CD-Rs thrown away so far)?:( :confused:
  2. nathan_silly
    nathan_silly
    Why not use CDRW's?
    You can screw up until you get it right.
    btw, disable windows writing feature.
    Nathan
  3. phil_evans
    phil_evans
    May 24, 2002
    186
    16
    Singapore
    Nathan,
    Good idea to try a CDRW disk but I still want to copy a data CD for a work colleague who has just a CD reader.
    I tried disabling the XP writer option in the drive propertires too - is that what you mean?
  4. nathan_silly
    nathan_silly
    Yeah, right click on the drive, and disable the option.
    Not sure- do you need ASPI?
    Nathan
  5. boogie man
    boogie man
    Dec 4, 2001
    233
    19
    Sunny Berkshire !!
    have you tried nero burn for dvd burning you can get a free demo for there site at ahead.de alot better then Easy CD Creator Basic.
    Boogie man:clap:
  6. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    How have you got the ide drives configured, you'd normally set a writer to secondary master.
  7. phil_evans
    phil_evans
    May 24, 2002
    186
    16
    Singapore
    I assume I don't need any ASPI drivers - there's no mention of it by Samsung, MS or Roxio as far as I can see.
    John - yes the drives on the 2nd channel master.
    My plan when I get some time (and patience) is:
    Check PIO/DMA settings in device manager
    Try some registry settings mentioned in KB article 308591
    Try the KB article 320174 download (should be in SP1 already)
    Oh, and buy some more CD-Rs. I'll try Nero as part of the diagnosis too.
    Thanks for the suggestions.
