Help - Network Socket Wiring Help
Discussion in 'Desktop & Laptop Computers Forum' started by richkeys, Aug 3, 2004.
  1. richkeys
    richkeys
    Jan 16, 2003
    19
    London UK
    Dear HCPC forum,
    can you help me?
    i'm in th e process of renovating a friends house a the moment and we want to put a network sockets in 4 rooms, dining room, kitchen, bed 1 and bed 2, these sockets will be connected to cat5e cable and all run to 4 sockets in his lounge where his main pc will be.
    Therefore, taking just the kitchen as an example, we will have 1 socket in the kitchen directly wired to a socket in the lounge.
    The purpose of these sockets is allow him to have his main pc in the lounge then connect say a laptop or other network device in another room and have them communicate to each other...
    PC (in lounge) ---- Network Cable ---- Socket on Wall (lounge) ---- Network cable under floor ---- Socket in Kitchen ---- Network Cable ---- Laptop
    1. Do we need to wire these sockets in a particular way, like crossover? or can I can connect them in the same way at each socket?
    :thumbsup:
  2. richkeys
    richkeys
    Jan 16, 2003
    19
    London UK
    mr. bump
  3. drum63
    drum63
    Nov 20, 2003
    144
    Kent
    +5
    Have I read the time correctly - did you really bump 2 minutes after first posting ?
    Yes you do need a crossover between them somewhere in the chain, but I would suggest connecting the fixed wiring straight through and just use a crossover patch cable at one end, (e.g. between the laptop and wall socket).
    That way, the fixed wiring could easily be used for something else in future if required (e.g. telephone) .
  4. The Dude
    The Dude
    May 21, 2004
    6,264
    Beverley, East Yorkshire
    +2,586
    the best approach is to straight wire the sockets, then get a 5 or 8 port port mini-switch and connect all the lounge sockets (and lounge PC) into this..
    the switch will only cost you £20 or so...
    make sure you wire up the sockets to the correct spec though.. you'll have probs getting 100tx connections if you dont..
