Now then,
I have my Xbox connected via crossover cable to my desktop PC which then uses a wireless lan to connect to my router/modem. I can access xbox live if I simply enable internet connection sharing on the wlan but the xbox indicates a strict NAT (attempts to forward the correct ports to my PC haven't fixed this) so now I'm trying to bridge the wlan and lan in an attempt to let my router see the xbox directly so that I can forward the ports straight to it. The problem is whenever I enable the bridge my wlan disconnects and won't reconnect until I remove the bridge. If I manually assign the ip settings of the bridge, the wlan appears to reconnect but I have no access to the internet and I can't even access the router configuration page. No matter what I try I just can't seem to get the bridge working properly.
Can anyone shed any light?
