help! Netgear dg834g no wireless!!
Discussion in 'General Video Gaming Chat' started by chillo, Jun 25, 2005.
  1. chillo
    chillo
    Sep 15, 2004
    768
    Northern Monkey!
    +34
    running Netgear dg834g with firmware v2.10.09 (this is the beta update, done about 2 months ago)
    can't get a wireless signal hardly at all! using wge111 and wg511
    Been happing for the last couple of weeks at random, seemed like i was on a 28k dial up when browsing internet on my laptop. Cant get wireless at all at the mo.
    SSID and wep all ok etc, can connect via cable to internet with home pc and (very long lan cable) to xbox live
    wireless card in my laptop just keeps scanning and not able to aquire a connection. Then sometimesjust connects! signal strength varies from 85% to 100%
    help!! any suggestions greatly appreciated! i'm tearing my hair out :mad:
    :lease:
  2. -Spike-
    -Spike-
    May 17, 2001
    1,624
    E.Sussex
    +297
    Hi chillo,
    So it has been ok?
    From the above I can only think that you might be getting interference.
    Try a different channel and see how that goes. Or if possible move the router, even a small distance may make a difference.
    I'd also upgrade to the very latest firmware. You say you are using .09 but I think there is .22 now.
  3. chillo
    chillo
    Sep 15, 2004
    768
    Northern Monkey!
    +34
    [​IMG]
    Spike your a genius! the ONE thing i should have tried first!!!!
    works great now!! :clap: :clap: :clap:
    cheers mate, the beers are on me :D
  4. -Spike-
    -Spike-
    May 17, 2001
    1,624
    E.Sussex
    +297
    No problem. :)
  5. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
    you talking about the same spike here lol
  6. o THE CHAD o
    o THE CHAD o
    Nov 22, 2003
    1,480
    London
    +83
    i had the same problem with mine,slow as **** speeds down to 2mps!
    changed channels and upgraded the firmware now its sorted.superb.
  7. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    Harsh but true :D ;)
