Help Needed !!
Discussion in 'Headphones, Earphones & Portable Music' started by hector-uk, Sep 13, 2007.
  1. hector-uk
    hector-uk
    Sep 27, 2006
    Hey folks !!
    I need some advice about buying a new system. I really need the system to have a recording function as i will be recording from my TV/Sky box via analogue connection alot. I used to have the old Philips CD system which had a cd-writer, which was good but broke down. Now since times have moved on i was wondering if its now possible to get systems where you can record onto hard drive etc instead.
    Of course all the other fancy features will be nice too i.e. streaming etc, but as long as it can record and the quality is good.
    Thanks for any help
  2. hector-uk
    hector-uk
    Sep 27, 2006
    anyone with any ideas??
    I was really hoping to get one soon. If there are none with hard drives are there any others similar to the philips which record to CD?
