Help needed
Coldfox
Hi guys.
I currently have an xbox 360. I would like to purchase the VGA cable so that i am able to use it on my computer monitor (samsung syncmaster 193v).
basically what i am asking is, will i be able to run in HD modes, is so which ones? , and also will i have to purchase some new speakers to use for sound output. i currently have some headphones i use for my computer. but i think the connection is different so it will not fit the jack.
Mac User
Anything over 1280 x 720 (720 p) is HD.. Im sure your monitor can display over that
Coldfox
ok cheers, does anyone else use their computer monitor, and if you do how is your sound output setup.
UglyChild uk
Untill recently I ran mine through my dell 2405fpw (great screen 1920x1200 capable component and vga connections and 24in. cant go wrong). For sound i had to run via optical cable to my cheapo creative 5.1 system.
Coldfox
Alright cheers, did you have to buy the optical cable seperatly? thanks
UglyChild uk
Peronally i didnt as i had one lying around. but yes you would need to buy one unless you have one with your 5.1 already.
stu.artd
When I used my 360 with my Dell 2405 I used a less sophisticated method than an optical cable. I used the parts in the pic below to connect the tiwn RCA audio connectors from the 360 to the 3.5mm cable from my speakers.
Similar threads
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
