Help Needed!!!
Discussion in 'Blu-ray & DVD Players & Recorders' started by AndyBlac, Dec 25, 2001.
  1. AndyBlac
    AndyBlac
    Dec 24, 2001
    40
    I have just orderd online a Toshiba SD-900E DVD player, as i have herd that it is the best DVD player out at the momnet, i have a Toshiba 42" Widescreen RP TV. (42WH18B)
    What is the best way to connect the two together ?.
    I have herd that Component connection is better than RGB scart is this true, I am using a QED SQUART (RGB ONLY) at the moment to connect my RP tv to my Panasonic A7. While i wait for my Tosh to arive.
    also, i have a Yamaha A2 Amp, is there a better amp availible, i know about the AX1 & AX2, but have been told that is not worth me upgrading to one of them is this true.
    Thanks for any help.
    AndyB
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Well, stick with the A2 unless there is something terribly wrong with it (faulty etc.) or you need the latest decoding formats available - then perhaps the new Denon amps are worth a look at.
    AX2 is IMHO a step sideways and AX1 doesn't offer all the new decoding like Denon.
    As for the connection stick with RGB via SCART or use component if the TV has a matching input but don't expect to see much (if any) difference.
