Help needed
Discussion in 'Xbox Forums' started by geese, Sep 15, 2005.
  1. geese
    geese
    Sep 13, 2004
    747
    28
    +37
    HI everyone
    I have Mortal Kombat Deception on my pc and will extract it to my xbox HDD. My C-XBOX TOOL2 software will not extract it to an iso.
    What can I do to transfer the game to my xbox HDD.
    thanx in advance.
  2. martwho
    martwho
    Mar 25, 2005
    1,293
    Southampton
    +57
    you're explanation is a little vague but i would suggest you try Qwix - it is a great PC based tool for creating/extracting xbox iso's!
    Hope this helps - if not elaborate!
  3. cra41g
    cra41g
    As mentioned, Qwix is an excellent program. It works especially well with Avalaunch - FTP boost mode!!! That's the only reason Avalaunch still exists on my Xbox!
  4. geese
    geese
    Sep 13, 2004
    747
    28
    +37
    Thanx you too.........A friend sent me MKD....and after using winrar I got an image file......but my c xbox tool which I usualy use wont convert the image. So I burned the game on dvd-r last night and used dvd2xbox copy in the xbox, and it did but whwn I try to play the game trough my xbox hdd it wont let me. I hope this explanation was a bit better....I hope.
    Thanx
