help needed
Discussion in 'AV Receivers & Amplifiers' started by tracey26, Sep 4, 2005.
  1. tracey26
    tracey26
    hi all..big problem here...i have a sony (str-de445) amp/reciever..im trying to hook it up to my jvc(av28ct1eks model) tv but having only 3 scarts at the back and no audio outputs...please tell me is it possible :lease:
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Do you use Sky or Cable (or freeview)?
  3. stewada
    stewada
    Jul 20, 2005
    45
    London
    I'm assuming you are using the TV as the tuner since you say "no audio outputs". It looks like EXT-1 and EXT-2 have audio outs. The manual seems a bit vague as to how you change these SCARTS (which you would think would be "in") to outputs. You're probably going to need a SCART to COMPOSITE (i.e. 2xRCA for audio and 1xRCA for video) adapter (shouldn't cost a lot) and then you will be able to use a standard 2xRCA cable to your Receiver.
    See: http://www.tvcables.co.uk/cgi-bin/tvcables/AD001.html for an example adapter.
    Page 22 of your manual talks about "Dubbing" which outputs the video and audio from the built-in TV tuner or any of the other EXT ports to EXT-2.
    The last page "Specifications" talks about the capabilities of your connections.
    Page 32 says that ...
    "The video/sound signal of a TV channel you are viewing is
    always output from the EXT-1 terminal.
    • Changing over a programme number (PR) also changes
    over the TV output from the EXT-1 terminal.
    • The video/sound signal from an EXT terminal cannot be
    output.
    • Teletext programmes cannot be output."
    If you're running any other devices as a Tuner (e.g. Sky, Cable, or a Freeview box) you should run your audio directly from them.
