help needed
Discussion in 'Video Streaming Boxes & Services' started by icebaby, Jun 25, 2005.
  1. icebaby
    icebaby
    i have just purchased an alpine cda 9855r headunit and 5755 sound processor,the trouble im having is when i connect them up i cant seem to alter the volume which set at 1 is really loud,you can turn the sound off from the headunits volume switch but it wont go up,the headunit as been switched to equaliser and powers the graphic perfect but im a bit stuck on how the volume doesnt work,separately the headunit works perfectly any help or info would be much appreciated
    thanks in advance
