Help needed
Discussion in 'Home Cinema Buying & Building' started by crazygant, Aug 26, 2013.
  1. crazygant
    crazygant
    Aug 25, 2013
    4
    Hi all going to be starting my home cinema journey shortly and wanted to know how you over came the problem of having one device output going out to two displays for example I am going to be using a sky / Apple TV and wanted to show on the led or on the projector . Thanks for the support
  2. dante01
    dante01
    Mar 5, 2009
    45,630
    +10,867
    You can either use an HDMI splitter to divide the single output into two from an AV receiver or you can utilise a receiver that incorporates more than one output.
  3. crazygant
    crazygant
    Aug 25, 2013
    4
    Thanks Dante did think of that but then was worried about picture and sound deterioration ... Only thing is that Apple TV does not have dual unless I get two of them which might have to be the thing ...lol
  4. dante01
    dante01
    Mar 5, 2009
    45,630
    +10,867
    A signal going via an active HDMI splitter will suffer no degradation. The output will be the same as the signal going into such a splitter.
    Apple TV? Why would you assume you need one with dual output? You simply connect it to the AV receiver via HDMI and split the signal coming out of the receiver. The same goes for any of your other HDMI equiped source components. All your source components are connected to the AV receiver via HDMI. The AV receiver processes and deals with the audio while the video signal is passed on out of the receiver via its HDMI output or outputs.
