Help Needed!
Discussion in 'AV Receivers & Amplifiers' started by ttpco, Nov 15, 2004.
  1. ttpco
    ttpco
    I have been looking around for some new compionents to replace my current system. Through personal experince I have found that most delaers want to sell you what they belive is best and what they have in stock. I need some unbiased help / recommendation
    I have about £500 to spend on Amp/receiver combo and up to £800 on speakers, was looking at Bose AM10's as have been using AM 5'S as have had these for a while and seemed OK to me. Would also appreciate it if any one knows of a wireless system for the home cinema like PC bluetooth - just saves all the wires going around. Appreciate any recommendations / help.
    Cheers :thumbsup:
  2. clarky78
    clarky78
    Nov 8, 2004
    1,845
    Helsinki, Finland
    +40
    dont know of any bluetooth devices, you can get some infrared speakers, but then you have to plug them into the mains to power them so you still have wire issues, unless your plugs happen to be right where the speakers go! And the one i have seen will leave much to be desired sound wise.
  3. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    What sort of speakers are you after? Small, medium or floorstanders. BOSE do not have a good reputation on here. If your looking for a lifestyle system go for the Mordaunt Short Genies. I have heard them and they rock for a small system
    http://www.avland.co.uk/ms/genie5.1/genie5.1.htm
    or the new Acoustic Energy P5 series.
    http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1820
    AMP
    Yamaha ax750SE
    http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1930
    Denon 2105 or 2805
    http://www.avland.co.uk/denon/avr2105/avr2105.htm
    http://www.avland.co.uk/denon/avr2805/avr2805.htm
    Marantz sr5500 or 7500
    http://www.avland.co.uk/marantz/sr5500/sr5500.htm
    http://www.avland.co.uk/marantz/sr7500/sr7500.htm
    The prices can be found cheaper if you look arround.
