help needed
Discussion in 'Projectors, Screens & Video Processors' started by cableguy, Nov 14, 2003.
  1. cableguy
    I want to improve the image off my projector.
    dvd is exelent. It's my Sky that looks crap.
    i have a Scancom XGA Theatre.
    Projection Technology RGB Liquid Crystal Shutter
    Projection System
    LCD Pixel number:
    480000 dots (800x600) x3
    Aspect ratio: 4:3 16:9
    Projection Lens Focus: Manual
    F number = 1.7 - 1.87, f = 21.3 - 25.6mm
    Zoom Ratio (1.0:1.2)
    Lamp Light Source: 165W Ultra High Efficiency Lamp
    Optical Features Optical System: Dichroic Mirror Separation & Prism combine Method
    Screen Size (projected distance): 0.76 – 7.62m (0.9 to 10.5m)
    Vertical Keystone correction: -15 to +15 degrees (automatic)
    Brightness: 1700 ANSI lumens
    Contrast: 500:1
    Illumination uniformity: 85%
    Colour reproduction: Full Color (16.77million colours)
    Audio Features 1W Monaural
    Frequency Range Pixel Range: 13.5MHz to 162MHz
    Vertical: 50Hz to 85Hz
    Horizontal: 15KHz to 92KHz
    Display Performance Native:
    800x600 SVGA (EMP-53)
    1024x768 XGA (EMP-73)
    640x480 (UXGA/SXGA/SVGA/VGA)
    Remote Control Features Functions: Input Selection (PC/Video)/Color Mode/AV Mute/ Freeze/Menu/E-Zoom
    Input/Output Terminals - Video S-Video Input: 1 x Mini DIN
    Composite Video Input:
    1 x RCA Jack
    Component Video: Mini D-sub
    15pin x 1 (when used with Analog RGB connector)
    Input/Output Terminals - Computer Analog Input: Mini D-sub 15pin x 1
    Monitor Output: Mini D-sub 15pin x 1
    Input/Output Terminal Audio Input: Stereo Mini Jack
    Audio Input: 2 x RCA Jack
    Control In/Out: 1 x RS232C Sub-D 15 pin
    General Characteristics Dimensions, without lens & feet: 240(D) x 315(W) x 87(H) mm
    Maximum Dimensions: 240(D) x 315(W) x 97(H) mm
    Weight: 2.9Kg
    Power supply: 100-120V/ 200-240V ± 10%, 50/60Hz AC
    Noise Level: 36dB (High brightness mode)
    Noise Level: 33dB (Low brightness mode)
    pace digital cable box conected to Scancom XGA Theatre
    re scart to yellow coposite conector.
    my problem is that setings on projector.
    it has 5 setings theater presentation ect.
    but when i connect the Scancom XGA Theatre
    with the suplied lead vga cable.
    i then switch projector to pc mode and great picture from
    cablebox is great bright and clear.
    but i canot get it to go 16.9,
    there are 2 other setings on projector menu for pc mode.
    these include component video (ycbcr) and (ypbpr).
    switching to any of these modes gives me 16:9.
    problem ? all white content of picture turns redish purple color.
    i am prety new to this and would realy be greatfull for help.
    ps i tried switching modes on cable box composite and rgb.
    16:9 and 4:3.
  2. buns
    Apr 29, 2001
    Sorry, I'm a bit sleepy and maybe not picking you up right.....
    The cable box is connected by scart to composite?
    What are you connecting with the supplied vga cable?
    What is it that you wish the 16:9 mode to do? Surely with a 4:3 projector, the 16:9 mode is really only used with anamorphic material so would do noting for cable material? Forgive me if I am wrong, I am obviously referring only to what my projector was like.
    All the best
  3. cableguy
    ok scart from cable box to 3 phono yelow to Scancom XGA Theatre
    vga cable goes from Scancom XGA Theatre to projector,
    looks like ile have to get another screen for sky viewing.
    the screen i have is 7ft widescreen.
    could you explain what these modes do on projector.
    both these setings bring down picture size to fit screen.
    but picture goes red and purple color.
    is there a way of using these setings before i get another screen.
    converter ect.
