Help needed with Xbox!!!!!
Discussion in 'Plasma TVs Forum' started by bluevortex, Mar 12, 2005.
  1. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    trying to hook up xbox to pW7 through skybox, can this be done?
    I have syncblaster cable (scart to VGA) going from sky box to plasma. i was trying to use the VCR scart input on sky box to connect the xbox, but get no picture only sound. I have the denon 500 dvd/amp connected via component to plasma and that is the only input board i have on the PW7.
    Can anyone suggest a way round this. Can i only do it with seperate input board?? Hope not
    Blue :confused:
  2. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    anybody??
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,359
    2
    4
    137
    Garstang, Lancs
    +1,632
    Seeing no experts are replying I will make a suggestion, make sure your xbox is set to 50hz (settings, video), also make sure the video input is not just an output (see manual).
    I might be talking rubbish but no-one else is replying.
  4. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    i will check my settings on my xbox with the other TV.
    i was under the impression you could put a console through the sky box and it should work when sky is set to standby. . . perhaps i misunderstood, sound no problem, just lacking picture.
    Thanks for your suggestion matey :smashin:
    blue :rolleyes:
  5. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    the vcr scart does take rgb in and you should be able to pass it through.....only thing is it will override sky while it is on so you can't leave xbox game on pause and watch sky (it will work whether sky is on standby or not). What xbox cable do you have?
  6. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    just have the bog standard cable from the original Xbox that was released.
    When i plug the scart into the VCR slot on Sky box and turn on xbox nothing happens, if i turn sky to standby i can hear sound from xbox but no pic
  7. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    is that original cable rgb?....if not you may need to get one of the hi def ones, you can get one with optical out if you have a spare input on your amp.
  8. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    i dont think its RGB, its video, audio L audio R (yellow, red and White) in the optional scart unit thing. very technical hey!
    I have the Denon 500 dvd/amp and tried putting the scart into Video in but again same thing, just sound no picture.
    So i assume it can be connected in this way through sky box? Where can i buy a better cable? Curry's?? Heaven forbid!
    Thx Mep
    Blue
  9. John
    John
    Dec 13, 2002
    11,683
    +3,350
    Official MS advanced scart pack is the way to go. The original XBox cable will only feed composite , and you don't really want that .
    If your plasma has component input , and you would consider a hard/soft mod , then you could go for the MS hi def pack (it will work with the box unmodded tho) . I used to daisy chain my Xbox through sky with the MS scart , and was very happy with the results :smashin:
    I keep saying MS , I hear you cry . Well , both sets retail at about £20 each and people have various results using non MS cables . Better to shell out the extra £5 than to have to shell out the full £20 on top of the first purchase.
    Its always worth posting a wanted ad in the classifieds here . Both flavours come up quite regularly
    Good luck
    John
  10. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    agreed...ms is best route........and you should get a much better pic too mate
  11. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    john/mep
    thanks for the advice. . will shell out for MS pack, altho i could be tempted by the hi def component leads but i would imagine as i use component for dvd it would be a pain in the ass changing leads round everytime.
    Blue
  12. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    it would become a pain real quick i reckon :)
  13. ap69
    ap69
    Jan 28, 2005
    430
    +15
    chaps - am thinking of getting the MS advanced scart pack (anyone suggest any retailers?).
    Just a few questions - can I use it without any modifications at all to the XB (And is it worth it in this case?), and presumably I'd have to run a separate audio lead from the XB to my plasma if using component connections?
  14. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    yes would need sound to amp or screen seperately...don't need modded xbox and should be better pic anyway than standard cable...try audiovisualonline.co.uk or whitedog they may do them
  15. ap69
    ap69
    Jan 28, 2005
    430
    +15
    mep - thanx
  16. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    no worries mate
  17. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    got the MS advance scart pack today. prob solved! cost me £20. could have got one cheaper on ebay but hey couldnt wait that long and they had them in curry's 5min down the road. It works nicely, might buy the audio cable to go with it.
    Thanks again
    blue ;)
  18. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    good stuff blue!
  19. tags
    tags
    I think you need to set your sky box to scart control on as well, so it will switch when it recognises another source.
