help needed with xbox live update
Discussion in 'Xbox Forums' started by mcaw, Mar 7, 2005.
  1. mcaw
    mcaw
    Sep 1, 2003
    93
    My son uses xbox live to play halo etc, and now wants to play Project Gotham Racing 2 online. WHen the game starts up, it says an update is needed to play, and goes to a download screen. after about 3-5 minutes, it says "xbox live not responding". The download bar did go up a notch, so I think it is doing something. Should he just keep trying, or is there something else wrong. He can still connect and play Halo.............
    martin
  2. nero0410
    nero0410
    Jan 5, 2004
    12,702
    Weston Super Mare, UK
    +5,051
    Quite a strange one there. I didnt have that problem. Do all the usual: make sure cables are connected ok etc....I'll put mine on later and see if I have the same problem with a new live game I bought, and if I have the same problem Ill try to resolve it and get back to you
    tris
  3. mcaw
    mcaw
    Sep 1, 2003
    93
    After he gets the "not responding" message, if he switches back to Halo, he can play online no problem, so I'm sure the cables are okey.
    Maybe I need to switch off the firewall on the router for an update ? I'll try that tonight.
