Help Needed with Video Standards Conversion
Discussion in 'Projectors, Screens & Video Processors' started by RwArms1, Mar 16, 2006.
  1. RwArms1
    RwArms1
    Mar 16, 2006
    54
    hi
    first post on the board - I purchased a u.s specification component called sony locationfree, it comprises a base station & lcd monitor, when you feed the base station a signal it uses wifi to send the audio & video to the monitor, my problem is this, the product is u.s specification so i assume the signal needs to be in ntsc, i have stepdown voltage transformers & a pal to ntsc convertor, when i send the signal through the convertor ( using scart to 3 phono plugs ) i get a black & white rolling picture & when i connect the cable straight through i get a colour picture which rolls, can anyone advise me what to do to stabilise my picture, should i have opted for a different kind of convertor ??, or does the problem not sound like its to do with the pal - ntsc conversion ??
    thanks
    rob
