B
Bushwacked
Just got my hands on a Tosh XS34 but I have three questions / challenges...
1. I can't find the code for the remote to control my TV, it's an old Sony TV. Do you know if there are anyother codes out there, I've tried all the ones in the manual?
2. I've got the Sony VTX-D800 Freeview box, and have entered the two codes in the manual, 0030 doesn't work and the other does to a degree but not as expected as I can't change the channel using the "CHANNEL" keys. Is this normal? I don't want to have to lift the flap everytime I want to change my sat box channel.
3. The most concerning problem is that I can't get sound to play when I have recorded from the Freeview box to the HDD. I do get sound when I play a prerecorded DVD though. I'd appreciate some help as I just can't figure this one out...
HELP!!!
Thanks in advance.
HELP!!!
Thanks in advance.
