Help needed with Sim2 Ht300
Discussion in 'Projectors, Screens & Video Processors' started by godzilla, Feb 6, 2003.
  1. godzilla
    godzilla
    Oct 10, 2002
    661
    Lightwater
    +14
    Still very happy with my Sim2, but:
    1) I'm having trouble getting a component picture from my Denon DVD-A1, the picture comes out split vertically in two when viewed on the YCrCb input. S-video is fine (and can be upconverted to component by my A1SR, but that is not progressive scan obviously).
    2) Has anyone come up with a relatively simple way of attenuating some of the colour wheel whine? I've been told boxes aren't a good idea due to cooling, but is a foam lined plywood sheet going to make any difference for example?
  2. chips
    chips
    Dec 3, 2001
    2,380
    41
    2NM S EGTF
    +22
    Are you using the correct input on the sim 2 for progressive?
    YCrCb 32..... not YCrCb 15 which is for interlaced.
  3. godzilla
    godzilla
    Oct 10, 2002
    661
    Lightwater
    +14
    I'll give that a try tonight, but I think I did try all the permutations, but I can't be certain.
  4. godzilla
    godzilla
    Oct 10, 2002
    661
    Lightwater
    +14
    thanks chips,
    I can now get a picture by using the ycrcb 32 input as you suggested, but looking at eg the menu page of a dvd there is a slight lateral distortion about 1/3rd and 2/3rd up the screen where a few lines seem displaced (any still vertical line like the edge of a menu icon has a kink at these two points).
    This distortion is not visible on the interlaced 15khz setting.
    Most annoyingly, I still can't get any picture if using my Denon A1SR as video switcher rather than directly connecting the dvd player. An "out of range" message flashes up in the centre of the screen when using the ycrcb 32 input when the signal is routed thru the amp.
    Any advice gratefully received!
  5. chips
    chips
    Dec 3, 2001
    2,380
    41
    2NM S EGTF
    +22
    Can't help with either I'm afraid, both sound like Denon Issues.
    I don't get the picture distortion you describe with my Toshiba.
    I would have thought that the A1SR would be able to pass a progressive signal though :confused:
  6. Gary Nash
    Gary Nash
    Dec 15, 2002
    338
    Dorset
    +17
    I've noticed horizontal distortion and sideways 'twitch' with svideo and component interlaced connections - but only with PAL discs.
    Spoke with OWL, who were aware of this problem.
    The fix is to change the video mode (I think thats the option - you'll find it on the brightness menu) from 'normal' to 'vcr' and the picture stabilises.
  7. -Spike-
    -Spike-
    May 17, 2001
    1,461
    E.Sussex
    +171
    Had the same on my HT300.
    Wondered if it was a Macrovision issue as I didn't notice it on PAL DTS demo discs :confused:
    I've since switched to using progressive scan which eliminated the problem, plus I prefer the picture (IMO) :)
