help needed with new projector
Discussion in 'Projectors, Screens & Video Processors' started by jmadoyle, Jun 1, 2005.
  1. jmadoyle
    jmadoyle
    Feb 15, 2005
    13
    just recieved my new sharp xvz91 dlp projector, all was fine for first 15 hours,
    then white broken lines appeared top left above the picture, i am using a 10m
    component lead from a pioneer 575a dvd player, i have attached a picture displaying the problem.
    its my first projector and i have no ideas what it could be
    any advice would be greatly appreciated
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    Doesn't look like a problem, looks like extra info such as subtitles or closed captions which normally are cropped from the picture but sometimes on some DVDs they can be visible. Do you have an "overscan" facility on your PJ which will effectively lets you do a slight "zoom" on the pic to get rid of such things...PJ :)
  3. jmadoyle
    jmadoyle
    Feb 15, 2005
    13
    thanks for the swift reply
    i will have a look to see if i have that facility on it,
    the thing is the same dvd film i played two days ago gave me no such problem,
    with all the same settings on both the dvd player and projector.
  4. jmadoyle
    jmadoyle
    Feb 15, 2005
    13
    tried your suggestion, still there, its also visible on the screensaver for the dvd player,
    also tried different component leads to no avail,
  5. marker
    marker
    Had the same problem with my epson tw10h, i just used my option to move the picture up slightly, never seen it since...
  6. jw250
    jw250
    Nov 10, 2004
    148
    London
    +13
    I've seen this on more than one projector, including my own Sim2. As PJTX100 says, it looks exactly like the data (subs etc.) information stored on the disc, like teletext info that you can see on TVs sometimes when the broadcaster messes up. I don't know about the Sharp, but the "position" setting on my projector enabled me to shift the image up or down etc. to push the data stuff off the bottom (or top in your case) of the image. Think of it this way, on our regular TV's our Pal broadcast only displays 576 of the 625 that are broadcast - the difference being used for data, sometimes you can see it, near ad breaks etc. A projector is capable of showing those 'hidden' lines so I think its all in your setup - there should be some framing, shift or position options on the menu somewhere.
  7. Geesus
    Geesus
    Dec 23, 2003
    2,332
    116
    +739
    I had this along the bottom, but only on certain discs - Oldboy for one - as has been mentioned, I just moved the image 'up' slightly and have had no trouble since.
    Had it with Shrek at the top of the screen on my old TV too :D
  8. jmadoyle
    jmadoyle
    Feb 15, 2005
    13
    thanks for all the advice guys
    this problem is still visible on the dvd logo screen before i put on a film, and another thing, it seems to only happen in progressive scan mode on the dvd player, i have tried it with another player is it is also there,
    the thing is it has only occured in the last few hours of use, playing the same films as before.
    once again, many thanks for all the replys
