Help Needed With My New Panasonic S97
Discussion in 'Blu-ray & DVD Players & Recorders' started by colinw, Mar 15, 2005.
  1. colinw
    colinw
    Jan 16, 2005
    499
    +23
    Ok i need some help here, i just got my S97 today and i cannot get the component outputs to work with my philips 32pf9986 tv. While i'm in the dvd player setup menu via rgb scart, as soon as i select component out i loose the menu !!! obviously because there is no rgb out now, but when i go dvi input on the tv all i ever get is "picture format unavailable" on the screen ??
    The tv came with a dvi male to component female which i am using with a pair of phono leads at the moment.
    It says in the manual to turn off hdmi video out to use component outputs which is what i done.
    What am i doing wrong. Help.....
  2. colinw
    colinw
    Jan 16, 2005
    499
    +23
    Nevermind now, I managed to get it working finally :)
    I eventually found the progressive scan setting in the DVD player options that I couldn't find before, and thus set the picture format to 625P :thumbsup:
