help needed with lg 43uf770v
Discussion in 'LG TVs Forum' started by PAULRYAN52, Jul 8, 2015.
  1. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    595
    Liverpool
    +11
    hi, I've just got the LG 43uf770v, is it possible to get the sound for netflix going through my roth neo soundcore, here's how everything is connected
    blu-ray player > Roth hdmi 2
    Virgin Media Tivo > Roth hdmi 1
    tv hdmi 2 (arc) > Roth hdmi out (arc)
    blu-ray and vm tivo work through the roth but when i watch netflix there's no sound
  2. hodg100
    hodg100
    Reviewer & News Writer
    Aug 8, 2005
    14,105
    3
    4
    +4,468
    I'm not familiar with either of these but is your Netflix app outputting 5.1? If so, switch to stereo and I would bet it will output the sound.
  3. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    595
    Liverpool
    +11
    I've sorted it by telling the TV not to use its speakers
  4. Mash86
    Mash86
    Jun 30, 2015
    27
    3
    South Wales, Swansea
    +3
    Hi Paul. I have also purchased an LG 43UF770V. So far I am very happy with the TV. Do you have an issue with lip syncing? If so do have any advice on a cure? i have also been struggling to find a way to view pics/videos from my iPhone to the TV. Any help would be greatly appreciated:)
  5. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    595
    Liverpool
    +11
    Sorry I don't have lip Sync problems, I'm having a different problem when I turn tv on it turns my blu-ray player on, it even turns it on when I press exit to quit Netflix
  6. Mash86
    Mash86
    Jun 30, 2015
    27
    3
    +3
    That is a strange problem. Have you got the Blu Ray player plugged into hdmi 2(arc) if so try swapping it to another one. Hope that helps
  7. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    595
    Liverpool
    +11
    It's connected to the sound bar which is connected to hdmi 2
  8. Mash86
    Mash86
    Jun 30, 2015
    27
    3
    +3
    The arc function is used to control multiple appliances with just one remote. So try plugging the sound bar in a different hdmi.
  9. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    595
    Liverpool
    +11
    But won't that stop the sound going through the soundbar for Netflix
  10. Mash86
    Mash86
    Jun 30, 2015
    27
    3
    +3
    Im afraid this is where my knowledge ends as I do not use a sound system only the TV speakers. I would of thought that if everything is plugged directly into the TV then there should be no issue with sound?
  11. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    595
    Liverpool
    +11
    ill figure it out
  12. JayCee
    JayCee
    Jan 20, 2004
    23,998
    Lanarkshire
    +2,617
    No, you've got the wrong end of the stick there.
    Google ARC (Audio Return Channel)
  13. Mash86
    Mash86
    Jun 30, 2015
    27
    3
    +3
    Sorry my bad. I thought that was a function of the arc.
  14. MrGamer
    MrGamer
    Jan 19, 2009
    138
    +15
    Hi im considering buying this TV. Any thoughts so far? Hows th PQ and do you play games at all? Wondered about the input lag? Cheers
  15. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    595
    Liverpool
    +11
    Pq is great in my opinion and I don't game sorry
  16. MrGamer
    MrGamer
    Jan 19, 2009
    138
    +15
    Thanks Paul, just the lag info needed before i take the plunge....
  17. Mash86
    Mash86
    Jun 30, 2015
    27
    3
    +3
    I am still sussing out the TV myself as I've only had it a week. So far the PQ is very good! If your looking for deep blacks then there are better TVs out there, due to LG UF770v using an IPS panel.
    I have only played GTA V and found that there was input lag and was quite noticeable. If you change to game mode then it is barely noticeable but you lose PQ. I'm not a serious gamer so I can't comment much further than that I'm afraid.
    For the money it is a superb tv with an excellent UI (webos 2.0) and the best viewing angles, if you do not sit dead in front of the TV this will be a great benefit. Hope this helps:)
  18. MrGamer
    MrGamer
    Jan 19, 2009
    138
    +15
    Ok thanks for that. Im used to plasma so the blacks might be a problem. The lag might be ok if its fine in game mode. Cheers
