Help Needed with Laptop/DLP
Discussion in 'General TV Discussions Forum' started by chantman, Mar 18, 2005.
  1. chantman
    chantman
    Hi All,
    I have a Toshiba 46" DLP. I want to hook my laptop to it to play games. The Tosh only has and HDMI port. So, I bought an HDMI to DVI cable. My laptop only has a VGA port, so I bought this: http://www.newegg.com/app/viewProductDesc.asp?description=14-999-504&depa=0
    I've turned the tv to the HDMI feed, hooked everything up, my laptop recognizes the Tosh, I change to the proper resolution and then tell Windows to "extend my desktop onto this monitor" and nothing happens!
    Did I do something wrong?? Is this impossible?
    Any help is greatly appreciated!
    Thanks!!
  2. mrmoo
    mrmoo
    Jan 10, 2005
    517
    +19
    That will not work as your laptop is putting out an analogue signal. The converter only converts the pin configuratioin not the signal. Use a VGA to VGA lead.
  3. Razor
    Razor
    Dec 15, 2004
    37,727
    2
    +12,503
    Mrmoo is correct :hiya:
    :thumbsup: :thumbsup: :thumbsup:
    Also upto date drivers may give you a better pic. What graphics card have you got? :)
