Help needed with Hitachi monitor
Discussion in 'Plasma TVs Forum' started by jwd9, Nov 25, 2004.
  1. jwd9
    jwd9
    Does anyone have experience of driving an Hitachi plasma monitor without the AV300E multimedia box? It has just the DVI-D input and won't take anything else. I have used a PC with a DVI output card, but don't get any result. The screen will power up OK and goes through it's colour check, but will do nothing else.
    I am loathe to pay £650 for an AVC if the monitor input board is damaged.
    Model is 32HDT21M
    - Just a thought, might a different tuner with a DVI-D output drive it?
    Many thanks
    Dave
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    If its only got the DVI input, I suspect it might only work with the media box as the Hitachi screens that are designed to work without it have more inputs.
    AFAIK, you can't run the Hitachi 'TV' panels without the media box.
    John
