HELP needed with connectivity please
Discussion in 'Cables & Switches' started by Scoobydoo, Nov 25, 2004.
  1. Scoobydoo
    Scoobydoo
    Sep 26, 2004
    New to all this but getting:
    Pioneer DVR420
    KEF2005.2
    Yamaha RXV650
    Skybox
    Philips TV (2scart)
    Any advice on best way to connect all these together.
    :lease:
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Looks like your Yamaha is very similar to mine, in terms of connections. If your "Sky box" is Sky+ or if it has S-Video output, then connect it via S-video. Otherwise you will have to buy a SCART to RCA jack (phono) cable, and go in with composite video. Then more of the same to connect from the Yamaha to your TV (unless your TV has S-Video inputs).
  3. bobbypunk
    bobbypunk
    Scart from DVDR to TV
    Scart from sat to TV
    scart from sat (2nd scart) to DVDR (2nd scart)
    Optical DVDR to Amp
    2 RCA - 2 RCA from Sky to Amp (Optical if it's sky+)
    Then speakers to amp and sub to amp.
    Depends where you live but quite a few dealers would install for you anyway.
