help needed with adobe encore dvd
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by den911, Jun 6, 2004.
  1. den911
    den911
    my question is quite long , so i will only go in to the basics and hope someone uot there is a encore specialist . my problem is that on my now third attempt of adding animation to my buttons , then renering motion menu , wich is fine in preview will not complete build . on my first attempt it transcoded both video /audio then moved on to next video then audio , then on the third it transcoed video then audio after it got to 100%it locked and would not go to next task of burning , this has happened again twice can anyone pleasehelp me out . i have updates for encore , i also have posted help on adobe forum and have not had one reply any help on this matter would be greatly appreciated .
