Help needed with a simple Excel formula
Dufresne
Could you help me with a simple excel formula please (I can't remember how to do it :blush: )
I have a worksheet called SOURCE containing data
There is a second worksheet called PRINTOUT that extracts the data, ready for printing the report, so the source data is never touched. This is updated automatically with =Source!A1 etc
If there are blank cells in the source worksheet, the printout worksheet returns a '0' (which I don't want)
I can't remember how to make the printout cell blank UNLESS there is something entered in the source cell
I've done something similar, but it only works with numbers I think because of the SUM function being used;
=IF(SUM(D136:D166)=0,"",SUM(D136:D166))
So it says if the sum of a range of cells equals zero, return blank. Or return the sum if it's not zero.
So I need a formula that says If the contents of a cell are empty, return blank. Or return the contents if it's not empty.
Sorry if I'm being thick, but I appreciate any advice :)
Dufresne
I've worked it out myself :smashin:
I used
=IF(ISBLANK(Source!A1),"",Source!A1)
Happy to archive the thread (I'm not sure how to do that as it doesn't appear in thread tools?)
