Help needed with a macro - TSU7000
gilford
Right then, I have nearly perfected my own PCF apart from this on darn thing :mad:
I have done a macro to go direct to the HD channels on sky
TV Guide>0.5 sec delay>Red Button
All works fine:smashin:
Trying to do Sky+ Planner -
TV Guide>0.5 sec delay>Green button
Nothing:thumbsdow
Tried various changes in the delay but nothing :confused: :confused:
Anyone else experienced this or know of a work around?
Cheers, any help appreciated:thumbsup:
gilford
100% bud.
I use it all the time!
I have tried doing the macro on the PC and on the remote itself????
AAGGHH! lol
stevelup
Truly bizarre.
I only have one suggestion - it probably wouldn't hurt to relearn the "TV Guide" and "Green" buttons.
Just in case... I really can't think of anything else.
I've not got the same hardware as you (Marantz RC5200 and normal Sky) - but I was able to recreate the same macro without any problem.
Steve
BrianC
I'm also successfully using a similar macro to access the planner (I also have one for my favourites). Is the green or TV Guide buttons that you are referencing in the macro an alias/link or are they available at the top level of the device as well as where you are referencing it? This has caused me a few problems in the past.
