Help needed! what tv!
Discussion in 'TVs' started by Keithhampson, May 1, 2005.
  1. Keithhampson
    Keithhampson
    Apr 22, 2005
    673
    +6
    I have £600 to spend on a 32 Inch tv, I have looked at quite a few now in dixons, currys and comet, I am not going to buy from there as it is too exspensive, everytime I ask for help I am told different things as to which set is best for my money, no one gives me the same tv as being the best, I have picked out 3 from what I have been told and had a look at, they are:
    Sony KV32CS70
    Panasonic TX32PM11C
    Philips 32PW6518C
    What I want most is a good picture and good sound, they all look good in a shop with a dvd playing on them, but they are not side by side so its hard to compare, as too is the sound, I would like 3d sound are surround sound if possible, which I don't think the Pasasonic has, I could be wrong, can anyone give me some advice please, I have searched all over the net for reviews but could not find any, I it was a mobile phone I had wanted there are 1000's of reviews but TV reviews take some finding.
    Thank you very much
    Keith
  2. la gran siete
    la gran siete
    Oct 5, 2003
    24,771
    Deep in the bowels of sussex where the angloargies
    +1,766
    I kind of like this tv: http://www.beststuff.co.uk/finlux_82gf50.htm
  3. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    More than enough reviews
    Make sure that which ever you choose has 2 RGB enabled scarts as a minimum you are going to need them.
  4. billystevo
    billystevo
    Mar 13, 2005
    53
    9
    I went for a Panasonic for picture quality, bought one without the Dolby stuff as i think for sound you need to by a separate amp and good quality speakers to get the best. I don't think the sound from any telly with Dolby can match the sound of separates, but you have to pay for it. I have a Yamaha amp and Whafedale Diamond speakers and a Yamaha sub woofer. Its cost me about £500 but when you play your DVD its worth every penny.The sound is just as important as the picture, playing 2 Fast 2 Furious is like driving the car in real life , awe sum. :eek:
  5. gario
    gario
    Mar 1, 2005
    54
    +4
    Philips 32PW6518C
    This tv sells for £409.27 inc delivery at Ebuyer, check the customer reviews for this tv.
    Ive got its baby brother in our bedroom, the 24PW6518.
    IMO it a great little tv. :smashin:
    And you will have the best part of £200 left from your £600 budget. :)
    Looking foreward to hearing from the anti Philips brigade :rolleyes:
  6. IrishEyes
    IrishEyes
    Odd that you've posted a half dozen or so near-identical posts.
    Do you work for Philips or just a fan?
