Help needed w/ UD-M30 and pc audio
Discussion in 'AV Receivers & Amplifiers' started by Mervita, Jun 6, 2005.
  1. Mervita
    Mervita
    Hi!
    My ex left me with a DENON UD-M30 and I'm trying to make most of it! I've successfully connected an DVD player to LINE1 as (type CD) and now I'd like to connect my pc to it too. The problem is static noise on top of everything once I put the device on. I've tried the following setup: LINE1-PC as CD, LINE2-DVD as AUX and vice versa. The noise is present with tuner and CD player also and dissapears once I unplug it! I've looked through my PC audio settings (SoundMax integrated Digital Audio) but I can't find anything peculiar or odd.
    As you can propably tell I'm not very experienced with these devices so any help is appreciated!
