CaptainJames
I have the bookshelf under my tv and floors next to the tv since they offer more midrange and the floor speakers are nice all around. The two compliment each other well so whatever I buy would want to still drive speaker a/b. It looks like arcam does not support this so I may end up with the denon 6700.
As I was saying - latest "fixes".......who would buy an AVR with all those bugs?!
JBL have just release 1.46.
Fix list (v1.46):
IMS21645: Add DTS Neural:X & DTS Virtual:X to mode list if incoming format is DD2.0
IMS21647: Zone 2 audio seems affected by zone 1 upmixer
IMS21653: DANTE JBL using DANTE no audio from any 44.1kHz input (NET, CD, etc)
IMS21843: Height C & S speakers play Atmos Height middle source audio in 9.2.6 setup
IMS22108: Unit freezing when installing Dirac filters
IMS22358: DANTE – very low level click during Dirac calibration
IMS22410: When volume is 0 sub still had low output
IMS22416: Podcasts longer than 100 minutes display “—“ instead of time
IMS22428: Casting to AVR through spotify no longer wakes unit from standby
IMS22433: Strange characters appear on screen when changing volume
IMS22442: Front panel volume control goes up before down and down before up with Dante enabled
IMS22445: DANTE Burst of noise through all Dante channels with Atmos (A Star Is Born - 4K)
IMS22471: Grey bar appears on the screen if changes are made to the speaker types with the web gui
IMS22475: When control is set to RS232, internal test tones from web gui will not work
IMS22482: Sub can rarely go to high volume on power on
IMS22486: Streaming audio changing MCH stereo > Virtual X then skipping 5-10+ tracks could cause lockup
IMS22501: DLCT gets incorrect gain value from AVR unless the master output level is adjusted
IMS22525: 3D - OSD missing background
IMS22545: RS232/IP sending command 0x0D while unit is in mute shows volume on OSD but not front display
IMS22546: RS232/IP erroneous character displayed on URC controller
IMS22550: No sub out on ch13-16 with Auro and Speaker Types > Subwoofer > Present
IMS22705: “Display On Time” still active during update
IMS22725: Add volume control to web client GUI
IMS22732: Internet radio timer on display will start counting in letters for longer listening times
IMS22733: DANTE – pop at start of Dirac measurement
IMS22734: RS232/IP – Command 0x43 returns Analogue Direct for DTS:X source
IMS22738: Front panel shows “Bluetooth Not Connected” after being powered up from standby on BT input
IMS22743: RS232/IP commands sometimes not ack’d
IMS22830: Unable to change wifi networks from web gui
IMS22832: 24/96 Auro +EQ loses Auro (gices just DTS HDMA)
IMS22835: Allow choice to reset or not after update
IMS22858: Sub gain in “Speaker Types” menu does not apply so subs attached to ch13/14/15/16
