Help Needed To Set Up System
Discussion in 'Cables & Switches' started by hazz37, Jan 19, 2004.
  1. hazz37
    hazz37
    Having probs getting my system wired up to it's best.
    I have as follows
    1 plasma monitor:composite vid in, s-vid
    1 video: 2 scarts, composite, s-vid
    1 sat : 2 scarts
    1 DVD: 1 scart, s-vid, composite
    1 TV tuner: composite, s-vid
    anyone have the best solution for me
    Thanks in advance
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    serious! Plasma with S-video and composite only????
    AV amp????
    SAT (sky???) RGB out???
    Where are you?
  3. hazz37
    hazz37
    Plasma has DTV,DVD Input,comp vid output, s-vid output, and a vid/audio output.
    using Pan SC-MT1 for sound.
    Sky RGB in and out
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    I guess you are UK then? WHat plasma would help and a link to details mate.
  5. hazz37
    hazz37
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    As its has component inputs may is suggest a component DVD player not sure if yours has component out but may have. ist sky or sky+ if Sky+ use S-video Why TV tuner if you have VCR and Sky?????
  7. hazz37
    hazz37
    just sky, the DVD has component out, tuner as the picture is better than the VCR
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
  9. hazz37
    hazz37
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Geting a Quintro or Holdan HSR1000 Scart commander or the unit from Play Still doesnt solve the issue of no RGB scart on Screen!
    Unless you then want to put an RGB>S-vid or VGA converter, Getting messy now!
  11. hazz37
    hazz37
    might just get the convertor and the Quintro, then all is solved,,,,,,yes?
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Erm sorf of DVD>YUV sky to Svid/VGA + other RGB devices, The VCR to Composite and Tuner to what ever.
