Can i finish off where davidorff started?
Bit of a noob here... Im looking for a complete home cinema system that can give me what i need!
My current system is:
Pioneer PDP-436XDE
XBOX360
SkyHD
SkyHD goes directly via HDMI into the pioneer, which has a single Optical Digital Out for the sound. The xbox goes into the pioneer via component and also has a optical digital out.
What im looking for is a DivX playing 5.1 surround sound system with small sattilitte speakers (i do not need a hard drive or dvd recording funcionality) than can accomodate for both the optical out from the pioneer and the 360*.
My budget is £500 - although i would like to spend a little less...
*The 360 can plug into the pioneer via the 2 left and right RCA audio thingys, and the guy at comet said that would output via the pioneers optical digtal output as 5.1, but i didn't believe him, is he right? because if he is then everything would be alot easier....
Thanks a million for your help, i greatly appreciate it.
