EmmalLouise82
Hi Guys, I have need some advice on best way to connect my new Sony Home Cinema System (Sony BDVE4100) to my Sony Smart TV and my BT You View Box. I have been told that HDMI ARC is the best way, and I have checked and both the Sony home cinema system and the Sony Smart TV are ARC enabled. So presumably I can connect the two pieces of kit together with an HDMI cable (does it need to be a special one for ARC?) and the TV & Home cinema should work together? What is confusing me is then what is then best way of connecting my BT Ultra HD YouView box to the TV, presumably I need a second HDMI cable which goes from the BT YouView box into a different HDMI input on the TV? So that would mean I have two HDMI cables going into my TV - is this the right way of doing it, or should I use an optical cable? Sorry if I sound a bit dumb, but this is the first time I have tried doing this (my ex used to take care of this), so please go easy on me. Thanks Emma
xxx
