HELP NEEDED * sony DCR-TRv145E PAL * HELP NEEDED
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Shotgun Ali, May 4, 2007.
  1. Shotgun Ali
    Shotgun Ali
    Camera Model : sony DCR-TRv145E PAL
    when i turn my camera on i get a message saying
    c:32:10
    and alot of beeping.
    I cant record or playback footage and I need my camera sorting ASAP. If you know anything please reply.
    Very thankful,
    Shotgun
  2. sassan22
    sassan22
    Doesn't sound good. Here is what the Error code means:
    C:32:10 Tape loading failure. Unit cannot complete the load cycle.
    More than likely there is a mechanical malfunction, with either a bent lever, or guide, or a stripped gear. It's also possible that the mode select switch is defective. Labor is typically major, and parts average typically fall in at $20- $65.00.
  3. Shotgun Ali
    Shotgun Ali
    Thanks alot
