Help needed - SonicStage 3.1
Discussion in 'Headphones, Earphones & Portable Music' started by the68gun, Jun 20, 2005.
  1. the68gun
    the68gun
    Jun 20, 2005
    I have joined the nw-hd5 club and love the little machine. I can upload cds into the softward but when I try to populate the cd information, I start to go into gracenote.com, I get the registration screen, I tick the box, press next and it says that it is "unable to find the CDDB database" won't let me in and I am having to copy the information in manually. Has anyone had similar problems or can anyone suggest what is causing it not to find the database?
    Desperate (to speed things up!) :lease:
  2. clivem2
    clivem2
    Might be a proxy setting problem with your browser.
  3. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,553
    England, UK.
    +553
    It might indeed or poss also that you haven't registered with Gracenote yet?
  4. the68gun
    the68gun
    Jun 20, 2005
    It is when I try to register that it cannot find the CDDB - anyone got any proxy setting advice?
  5. the68gun
    the68gun
    Jun 20, 2005
    Hey thanks KeanosMagicHat - it was the proxy settings - if you set SS3.1 to no proxy works great - sooo happy now! :thumbsup:
  6. the68gun
    the68gun
    Jun 20, 2005
    Sorry - thx 2 Clivem2 also!!
  7. orb_cz
    orb_cz
    i have a similar problem: today when i tried to import a cd into SS it told me that i had to register for gracenote/CDDB although i've had SS for a while now am registered with gracenote. when it asked me if i wanted to register i clicked "yes" but nothing happened. i changed my proxy settings but it still won't let me register.
    anyone have any advice, i have no idea what to do?
  8. the68gun
    the68gun
    Jun 20, 2005
    Hey Orb - if you use the options and find where you can set the proxy settings inside SS3.1 - choose "no proxy settings" - that seemed to work for mine - and it is sooooo good when it works so keep trying.
