Help needed setting up Sky on second TV
JEB770
I have a main Sony TV with a Sky HD+ box and a second tv in a bedroom with a connection to Sky (not mult room). Sky is connected to the second tv via a coax cable which enters the tv aerial socket of the tv via an additional small box which has a "magic eye" attacted to it
I have just changed the old second tv for a new one (Sony KDL-32EX4B). The new tv works perfectly but I can't get the Sky channels to appear. I have called Sky and they confirm that everything is okay with RF outputs. There is a light on the little box with the magic eye and it is on.
Maybe it's just a setting on my new TV, but I can't work it out Can anyone please help me?
Thanks, John
Stevenage Neil
Are you using the TV's analogue, (not Freeview), tuner?
Stevenage Neil
Having had a quick look at the spec for your TV, it doesn't seem to have an analogue tuner. Hence no Sky via RF. You could try a video sender instead of RF.
logiciel
JEB770
Thanks everyone, especially Stevenage Neill. Tuned to channel 6 on analogue and Sky channels now appear.
Thanks again, John
logiciel
OK John - SN was the one who found you might not be able do it, but he won't mind sharing your thanks.;)
logiciel
My post now amended - now can I have a bigger share? :laugh:
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
