Help needed setting up recorder to dvd player
Discussion in 'Cables & Switches' started by infinity5500, Oct 7, 2004.
  1. infinity5500
    infinity5500
    Hi, another newbie here. I was wondering if anyone could help me with a problem that l have. The problem is that when l try to record a dvd to dvd using my pioneer 220 recorder and my sony dav dvd player l get no sound but the picture is perfect l only get this problem doing a dvd to dvd but not when recording off the tv or when l have transfered my vhs onto dvd. I would've normally used the computer with the dvd rewriter but it can't seem to read the disk so my only hope is the dvd-dvd option using the pioneer 220 and sony dvd player. My apoligies if l have rambled on a bit. Thank-you
