Help needed - S-Video problem - DVD or TV to blame
Discussion in 'Blu-ray & DVD Players & Recorders' started by rashomon, May 30, 2002.
  1. rashomon
    rashomon
    Apr 25, 2002
    119
    Ranthambhore Tiger Reserve
    +8
    Hi all,
    I have the following set up -
    JVC AV28R25 TV
    Wharfedale 750 DVD player
    IXOS 126AV Scart-Scart cable
    I've tried watching DVD's using RGB but the picture is just too dark and cannot be adjusted. Colour and sharpness is fine however.
    So, I tried to set up the gear to view using S-Video.
    I set the DVD player to output S-Video and I set the EXT-2 scart input on the TV to accept S-Video - but the picture shown was very washed out - I had to whack the colour setting all the way up to max and even then it was not really right.
    When the EXT-2 scart input is set to 'default' (i.e. not S-Video) the colours are fine ... but I dont think that this set up is accepting S-Video.
    I've also tried the above with the EXT-3 scart connection as well with the same results.
    I read somewhere that the Wharfedale DVD 750 does not give S-video out on the Scart but Composite instead - is this the reason?
    What might be at fault here - is it the TV? ... or the DVD?
    I'm sure the cable is ok as it works fine for RGB bar the dark display
    Thanks for any assistance.
    Regards,
    Rashomon
  2. Jase
    Jase
    Mar 16, 2001
    10,825
    United Kingdom
    +2,718
    Sounds like its the player to me, not outputting an S-Video signal like you mentioned.
    Hopefully a fellow Wharfedale owner will help you out.
    I´ll move this to the dvd forum.
    cheers
