Help needed regarding 5.1 speaker choice, ~£500 budget
Discussion in 'Home Cinema Speakers' started by SimonMallion, Apr 13, 2005.
  1. SimonMallion
    SimonMallion
    Feb 15, 2005
    78
    As topic suggests, I need some help.
    I had originally decided to buy the Mordaunt Short Avant Premiere Plus 5.1 speaker set (http://www.petertyson.co.uk/msavantpremiere.shtml) with wall brackets from www.petertyson.co.uk for ~£480.
    I started to get a bit concerned regarding the phyisical size of these speakers and wondered if they can output a decent amount of midrange?
    I dont want to buy floor standing speakers since I have a small child and don't want them damaged so I opted for a wall mounted option.
    These speakers would be mostly used for movies, in fact probably 80% movies, 20% music. The room size is about 20ft by 12ft. The amp I will be using is a Denon AVR1705. If I can afford another speaker then I would ideally like a 6.1 setup.
    I have heard people mention that Wharfedale may do a decent set with a good sound for about £500. Does anybody have any recommendations based on my criteria??
  2. benbo
    benbo
    Mar 25, 2005
    26
  3. cool hand luke
    cool hand luke
    If its any help Simon i went for the same speaker package from Tysons and am very pleased with it,its my first HC set up to.
    My room measures 18' x 12' and i have the speakers hooked up to a Yamaha amp and i have no complaints. :thumbsup:
    Go for it and you won't be disappointed.
  4. Antpink
    Antpink
    Jan 18, 2004
    468
    43
    Singapore
    +103
    80% movies/20% music, 20ft x 12ft room - I would say these would be a pretty good choice, as long as you aren't expecting them to go indecently loud. I have these in a 15' x 15' room and they are perfect for my needs (which are pretty exclusively movies and TV for this arrangement). I never had a chance to demo the Wharfedale 9 5.1 package though, which retails for similar price, but it does seem to be well reviewed, and you might want to see if you audition these as well.
  5. SimonMallion
    SimonMallion
    Feb 15, 2005
    78
    Thanks for the responses, I will try and audition the M30i, Mordaunt Shorts and Wharfedale Diamond 9's to see what I like the sound of best (and also which has highest wife acceptance factor).
  6. rishi
    rishi
  7. rishi
    rishi
  8. capt_janeway
    capt_janeway
    Sep 2, 2004
    307
    Kennedy Town - Hong Kong
    +11
    My set-up too :)
    But damn this forum...now considering upping my mortgage and converting my loft to a HC now the hubby has gone :devil:
