help needed.. 'Pronto' !
Discussion in 'Home Cinema Control & Remote Controls' started by Taz, Aug 4, 2001.
  1. Taz
    Taz
    I just took delivery of my pronto from Lets automate £140 (thanks General)
    Can anyone tell me how to make the backlight turn on when the screen is touched?<br />I have tried what the manual says but no joy.
    Taz. <img src="cool.gif" border="0">
  2. Timh
    Timh
    Sep 14, 2000
    5,205
    3
    3
    Altair-4
    +298
    Hold down the Pronto logo for about 5 second's, the page with battery leval and LCD timer's should appear, you need to press the down arrow at the bottom of the screen, you then get a page which allow's you to adjust the light sensor, just tap to adjust and set, mine is set in the middle.<br />Hope this help's
    Tim
  3. kmb
    kmb
    Jul 1, 2001
    Taz,<br /> You might also want to check that the LCD Light button in the setup screen is not switched to off and that the timeout is not set too short,<br />mine is set at 10sec.
    Hope this helps,<br /> kmb.
  4. Taz
    Taz
    Thanks for replying guys, but neither reply worked <img src="frown.gif" border="0"> the model is RU890 if anyone else has any ideas.
    <br />Taz. <img src="cool.gif" border="0">
  5. Arthur.S
    Arthur.S
    Taz,<br />I have the same model. It should do that 'out of the box'. The method described by Tim is correct. Try turning the sensitivity up to max. Maybe you've got a strange touch? <img src="smile.gif" border="0"> <br />How can you see anything without the backlight?
    [ 04-08-2001: Message edited by: Arthur.S ]</p>
  6. MartinB
    MartinB
    Jun 3, 2001
    54
    Shropshire
    As I understand it, none of them have light sensors any more, as the chemicals used are banned in the EU.<br />To get the backlight to turn on when touched, set the light level all the way to the right, not left as stated in the instructions.<br />Have you been over to <a href="http://www.remotecentral.com" target="_blank">http://www.remotecentral.com</a> ? It's invaluable.
    Martin.
  7. Taz
    Taz
    YEH! thats it! thanks 'Arf' <img src="biggrin.gif" border="0">
    nothing like the manual says but hey! its done now.
    <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0">
  8. Taz
    Taz
    Cheers Martin, done it! <img src="smile.gif" border="0">
  9. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    Glad you got one Taz. <img src="biggrin.gif" border="0"><br />Now you can spend eons like me twiddling it! <img src="smile.gif" border="0">
  10. Taz
    Taz
    General,
    Been playing with it since Friday!....... the Pronto that is! <img src="wink.gif" border="0">
