help needed poorly plasma
Discussion in 'Plasma TVs Forum' started by L.SKYWALKER, May 15, 2004.
  1. L.SKYWALKER
    L.SKYWALKER
    Dec 26, 2001
    134
    28
    Ashton-U-Lyne
    +53
    Yesterday my screen developed a problem,thin green lines appeared across the screen about 2in apart they disapeared after around 10 minutes.Then throughout the evening they came and went.Phoned av-sales and spoke to Andy and explained the situated , he sugested checking all connections and asked if the screen is wall mounted(It is) maybe I've tighted the screws to tight after having no trouble for 3 weeks I'm alittle worried to say the least.
    Today I tided up all the cables and double checked all connections and everything was going well untill 6pm when they came back.Again for 10mins then went ,the screen had been on for 4 hours wondering if the screen is overheating? feed back from something?or the wall mount needs coushioning?.
    I'm a little p***ed to say the least as it's taken me 12 months to buy one.
    Screen is a Panasonic th-42pwd6 connecting
    Sky through js RGB to VGA into pc port
    Dvd into componet board
    x-box in scart board
    Any advice is welcome do I need to call out an engineer? :rolleyes:
  2. PC Nut
    PC Nut
    Jan 11, 2004
    649
    South West
    +65
    Do the lines move, if so state direction.
    Forgot to mention you could vote in my POLL
    http://www.avforums.com/forums/showthread.php?t=133180
  3. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    L.SKYWALKER
    I think you may find it was the tv channel m8 i have the same on bbc 1 but if i have sky on i dont see it.
    But i have sean it 1 time on sky but it was the same on my 28 inc in the bedroom so its just down to the chaannel m8
  4. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    Hi Skywalker,
    could you disconnect other inputs and just try the RGB to Plasma VGA unit alone? Double checking cables is always a good idea. We're always on hand if you wish us to check the Plasma VGA unit out for you.
    All the best,
    Dr John Sim.
  5. L.SKYWALKER
    L.SKYWALKER
    Dec 26, 2001
    134
    28
    Ashton-U-Lyne
    +53
    HI guys the lines don't move in any direction just fade in and out and get stronger in colour they started off on sky and were about 2 in apart.Turned sky off and played dvd still there, but they faded away.Next time on bbc1 through sky, then 4 and finally ITV in picture. They are closer together and a few red lines as well.They didnt come on Sunday however screen was only on for 4hours watched dvd no problems.So for its been on since 3 and no lines so far!.
    If they come again tonight I'II just have the RGB vga conected if they come again I'II go back to scart and check.
    first picture was Friends on friday might need to zoom in alittle
    Fingers crossed they go away
