Help needed - Poor battery life!
Discussion in 'Photography Forums' started by Justhe1, Jul 3, 2003.
  1. Justhe1
    Justhe1
    Apr 5, 2003
    41
    Hatfield, Herts
    Firstly, I am not a digi-cam expert, so please be kind!
    I purshased a Kyocera Finecam S3 about 6 months ago, (before I was aware of this forum I'd like to add:blush: )
    I have mixed review's really, its OK for shots on a clear day but really can't cope with twilight at all :mad:
    My real problem though is the battery life - its awful, Its now got to the stage that even when fully charged I can only use it for a maybe 30 pics tops (& even then I dont use the screen!!)
    Its got a Lithium Ion 800mAh battery - can i replace this with one that will be better, and stay better for longer?!!?
    If so where do I look!!! - Oh and would I be within my rights to send the camera back directly to the shop or the manufacturer if I don't think its 100% acceptable..??
    Thanks in advance.
    J
  2. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    Unforetunately batteries are one of the compromises you make when going for a small camera and battery life on the Kyocera is always commented on in reviews.
    I dont think you would get anywhere on that score but then again Im no expert on law.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,789
    Somewhere in South Yorkshire
    +4,978
    Li-ion batteries are fairly resilient (better than Nicd and smaller than NiMh) but all rechargeable technologies can only function for a limited number of recharges - typically well into the hundreds. Li-Ion does not have the dreaded 'memory effect' that makes NiCds virtually useless.
    Batteries are rarely if ever covered by warranties.
    If the situation has worsened significantly since it was new, the first thing to try is a replacement battery - it is possible that the existing one is dying (perhaps prematurely). If this cures the problem then you can conclude that the first battery was suffering. On the other hand, if the problem remains, it indicates that the camera has developed some fault whereby it is drawing more current. In which case you probably have a valid warranty claim on the camera.
  4. Hugo Junkers
    Hugo Junkers
    I suppose this would be a good place to ask.
    Having only had my digicam for a couple of weeks I'm not really up on battaries so I've noticed on the battaries (NiMh ones) that they have different numbers. i.e 1700, 2200. Does this mean that the 2200 charge would last longer than the 1700?
  5. LV426
    LV426
    Jul 14, 2000
    12,789
    +4,978
    My guess is that the numbers you are quoting are in milliamp hours. In which case, yes, 1700 = it will produce a current of 1 milliamp for 1700 hours (or 10 mA for 170 hrs, etc), and 2200 = 1 mA for 2200 hours (or 10 for 220, etc).
  6. Hugo Junkers
    Hugo Junkers
    Thanks for that Nigel. Something else I need to buy then. :laugh:
  7. tomson
    tomson
    Jul 19, 2000
    1,918
    Berk'amsted
    +187
    Its worth keeping an eye out on ebay for extra camera batteries - i recently bought 2 brand new, sealed ones for my Nikon for half the normal cost.
